MMoexp:EA FC 26:All the New Skill Moves and How to Excel with Them
هنا تجد شروحات صيانة أعطال الشاشات Repair TV
ندعم الفنيين بشرح مبسّط وحلول عملية مفيدة
اضغط على عنوان القسم للدخول إلى المحتوى
ستجد خبرة سنوات من الفنيين المتخصصين هنا
تعلم خطوات الإصلاح بطريقة سهلة ومباشرة جدًا
شاهد جميع الموضوعات الخاصة بأعطال الشاشات
اطرح استفسارك في موضوع جديد عند الحاجة
وسيتم الرد عليك بالشرح الكامل في أسرع وقت
Seraphinang
مشاركات : 3
اشترك في : الأربعاء 2025/11/5 4:50 am
مشاركة غير مقروءة بواسطة Seraphinang »
With the launch of EA FC 26 just around the corner, players can look forward to a variety of new gameplay features, particularly in the skill move department. This season introduces four exciting new techniques that promise to enhance your gameplay experience. Let's dive into these fresh skills and FC 26 Coins learn how to utilize them effectively on the field.
Big Feint (2 Stars)
First up is the Big Feint, a dynamic dribbling skill designed to help players swiftly change direction and throw off defenders. To execute this move, hold the L2/LT button, flick the right stick left or right, and then use the left stick to choose your exit direction.
Mastering the Big Feint hinges on your timing and precision. When done right, it creates a sharp change in pace and direction, leaving defenders struggling to recover. With a 2-star rating, this move is accessible to many players, making it ideal for both those new to skill moves and seasoned dribblers looking to add flair.
Stop and Go (2 Stars)
Next is the Stop and Go, a versatile move that allows players to halt abruptly and then accelerate in a new direction. To perform it, hold the L2/LT button, push the right stick back, then forward.
This move is particularly effective for creating space and navigating around defenders. The quick stop followed by a sudden burst can catch opponents off guard, setting you up for a key pass or a shot on goal. Since the Stop and Go can be canceled, it seamlessly integrates with other actions, enhancing your overall gameplay.
Step Over Ball (4 Stars)
The Step Over Ball is a more advanced skill that requires a bit of finesse. To pull it off, hold the L1/LB button and flick the right stick forward, then either left or right.
This move is excellent for one-on-one situations against defenders. By dragging the ball across your body and shifting your weight, you can create space and leave opponents behind. The 4-star rating reflects its complexity, but mastering it can be a game-changer when facing skilled opponents.
Toe Drag Stepover (5 Stars)
Finally, we have the Toe Drag Stepover, the most intricate new skill move in EA FC 26. To execute this, spin the right stick in a specific pattern—either right, back, left or left, back, right—while holding the L1/LB button.
This move showcases exceptional ball control and body feints, making it a true spectacle on the pitch. When timed perfectly, the Toe Drag Stepover can bewilder defenders, opening up significant space for attacking players. Its 5-star rating indicates the high skill level needed, positioning it as a technique for the game elite players.
As you gear up for the release of EA FC 26, dedicate time to practice these new moves. With commitment and perseverance, you'll soon be executing them with ease, ready to dominate the competition.If you still want to get other players, you can ask for more guides and cheap Fut 26 Coins help at MMOexp. Don't miss out on this unique opportunity to play with one of football greatest icons!
ابوزياد
مشاركات : 23
اشترك في : الأربعاء 2023/4/12 12:06 am
مشاركة غير مقروءة بواسطة ابوزياد »
الله ينور يا هندسة
صيانة شاشة - عطل شاشة
اصلاح شاشة  - عطل تليفزيون
Repair TV
المتصفحون للمنتدى الآن: Amr zakarya, amrzakaria, Baidu [Spider], Hjkl, khaled ahmed و 26 زائرًا
